Alternative 5-speed?
Greg55_99
55
MA
If your interested, check out the MA5 truck transmission from the 2004-05 Chevy\GMC Colorado\Canyon.
http://cgi.ebay.com/ebaymotors/ws/e...d=1,1&item=7972697380&sspagename=STRK:MEWA:IT
Good points:
Bolts up to R154 bellhousing
Input shaft length 7.5" (R154 7.25")
Uses Chevrolet splined clutch disk and GM style THM 350 yoke
Upgraded version of Toyota trannies
Bad points:
Uses electronic speedometer
Gear ratio's not as good as the R154
Trans First Second Third Fourth Fifth
MA5 - 3.753 2.26 1.37 1.00 0.729
R150 - 3.83 2.062 1.436 1.00 0.838
R151 - 4.31 3.32 1.52 1.00 0.83
R154 - 3.25 1.95 1.30 1.00 0.75
If interested, Todd Kozak is selling these NEW for $375 <djd@acsworld.com> Such a DEAL....
Greg Williams
Greg55_99
55
MA
Oh yeah, one other "good" thing. The bellhousing it comes with will allow it (or the R154) to be bolted up to the GM Vortec DOHC 2.8L I4, DOHC 3.5L I5 and DOHC 4.2L I6. Try out a turbo on THAT!
Horsepower: 275 hp @ 6000 rpm
Torque: 275 lb-ft @ 3600
Applications: Buick Rainier, Chevrolet Trailblazer, GMC Envoy, Saab 9-7
Greg
Blue87T(Dan)
St. Clair Shores, MI
Interesting option.
I wonder why it bolts right up to our bellhousing? Luck of the draw?
I like to see someone try this. Hell, you can tell your speed by the tach anyway.
375.00 for a new trans sounds awful cheap though, wonder what the catch is.
Dan
Greg55_99
55
MA
Blue87T(Dan) said:
Interesting option.
It's a product of Aisin-Warner. It's an evolution of the original Toyota R series. There are a LOT of transmissions that will bolt to your bellhousing.
attachment.php
I like to see someone try this. Hell, you can tell your speed by the tach anyway. 375.00 for a new trans sounds awful cheap though, wonder what the catch is.
Dan
Talk to the man. Todd Kozak <djd@acsworld.com>
Greg
Blue87T(Dan)
I know Aisin. I work for GM.
I just have not heard of a bolt on manual option for the Supra before. Then again, since the R-154 seems to be able to take so much power, maybe no one has looked for one that much.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Yes these are aisin transmissions out of the new Chevy Colorados IIRC.
On the old SM.com boards, I think limequat or some one had already figured this out with a bunch of other people like DR J and more...that this will work on our cars.
I would really like to know though if they will handle the high hp.
supra90turbo
shaeff is FTMFW!
MA, 01440
there you go, then, Race Bred!
haha.
iirc, it was chevyeater who had been talking about this previously....
and a sincere hmmmmmm from me as my trans has 170k(mi) on it and is beginning to piss me off........ but the elec speedo output is making me wonder...... anybody thought of making an aftermarket speedometer work with the supra cluster before? kind of like paddlenbike and jt2ma71's boost gauges.....
limequat
Dissident
Detroit
We never figured out for sure if it would work, but there was a bit of discussion about it. My big draw to the trans is the triple cone synchros.
We can't say if it will handle the power, that's where the discussion stopped: "someone try it and report back". Aisin doesn't rate them for max capability, they rate them for max application which, IIRC, is about 250 lb-ft. It's a good bet, since they have the triple-cone synchros in the same overall package, that the gears aren't as wide.
As for the the electronic speedo, it'd be worth looking at swapping on a R-series output shaft and tail housing. That way you could keep your stock driveshaft.
limequat
Dissident
Detroit
heavyearly87t said:
A quick call in Canada and we find that its $1784.78 locally. Umm a rebuild would be cheaper here. Sux could have been a great fix.
Or you could get one off ebay for $375. My synchros are hating me, may be time to take the plunge.
