alignment tool...you didnt answer my question and closed my thread
spoolme
supra4umsfreak
May 9, 2005
320
Roswell, NM
what i was asking is do i need one to put the clutch on. sorry if i dont know anything about clutches and transmissions. thats what this place is for to learn.
SO do i need one to put the clutch back on correctly and if so where can i get one
THANK YOU CKANDERSON
will you please answer my question.
Ckanderson
2,644
The beach
NO YOU DONT NEED ONE!
the pressure plate AND disk slide onto the input shaft of the tranny. push the tranny into place, then bolt on clutch from the acess holes!
oh and do me a favor... dont make 2 threads.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
chriso said:
I always use an alignment tool. It centers the clutch disc within the pressure plate. If you don't use one, it will be nearly impossible to put the tranny back in. Here are some links to a tutorial I did on SF.
http://www.supraforums.com/forum/showthread.php?t=307132
http://www.supraforums.com/forum/showthread.php?t=307133
Do you have a W series transmission? The R154 doesn't need a tool, both the pressure plate and the disc slide onto the transmission input shaft. The input shaft does all the centering automagically.
I have yet to use a centering tool on an R154, and reinstallation has yet to be a problem.
shaeff
Kurt is FTMFW x2!!!!
11
Around
yes. for the w58 and alignment tool is your friend, for the r-154, it's pretty useless.
-shaeff
