Alignment Experience
Blade2001
61
TX
I need to get an alignment done, since I pulled the steering rack for rebuild, and balljoints replaced. I was thinking to go to a tire/alignment place close to work.. but should I go to a dealer for this? what is the general experience with supra alignment done outside dealerships?
thanks.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
It should be fine going to a regular alignment place. I even went to Sears and they got it done. As long as the car isn't lowered too much it should be fine.
Ish
SM Pimp
Socal
Make sure you ask them for a print out of the specs. Supra's don't really need anything (unless something's broken) when it comes to alignment. It's not like Honda's that need camber kits.
I'd go to a specialist that knows what they're doing and why.
Any more than 2" lowered and they're going to run out of adjustment in the rear and speaking of adjusters I'd crack all of them to make sure they move before going and replace any that are frozen so you're NOT paying the shop to do it.
Ish
SM Pimp
Socal
I forgot about this. I had to spray WD40 a few times before I got some of them to move.
8,900
The front end shop probably has techs that were just getting tired of the dealer in the first place. We had techs at the dealer that only did alignments. It was the only way to compete with the lower price front end shops.
8,900
I have seen cars driven right over the edge. But both times the owner after the fact mentioned the brakes had a problem.
I don't remember if the Hunter machine was damaged. But the Ford Ranger was laying against it.
Blade2001
61
TX
Thanks for the replies. Car is at stock height. IJ, what do you mean by adjusters? Are those the large bolts (2) that hold lower A-arm in position?
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Those I think.. Disregard the marks I made, I was showing something a while back.
viper92086
932
NJ
if u haven't gotten an alignment for a while i would spray some liquid wrench on the alignment bolts. Mine were rusted stuck and the alignment guy told me to bring it home and break the bolts loose for him so he wouldn't have to charge me extra. u gotta love honest mechanics
