So I've been having an issue with my alarm for awhile now, and decided yesterday to eliminate the problem, or, so I thought. I did exactly as this post says, too no success( see below). This is the "theft deterrent box" right?
If I did exactly as I was directed to what could be the issue? Could it be the door sensor? Because I know I always had to unlock the car from the passenger side to get in. If I didn't, and unlocked it from the drivers side the alarm would sound. If it is the door sensor how could I fix the problem with that? I didn't screw anything up did I? Is It possible I didn't do something right? or I did, and its something else? Any help would be awesome!
Re: My damn factory alarm...
you have a couple of options here. if the door sensor is NOT fried:
close the door with it unlocked
put your key in the door, then lock it.
wait a minute or so, then unlock it.
when you cycle locking/unlocking the door like this, it is supposed to reset the alarm.
or you could go under the hood of the car, find the two wires that go to the hood sensor (so if someone pops your hood, the alarm sounds) cut them, and splice them together. this will make the alarm think that there is a door open, in which case the alarm cannot be armed.
this is the route i took:
go under the dash on the driver's side. attached to the steering column way up under the dash near the firewall is the alarm computer.
here's a pic of where it is, its called "theft deterrent computer":
http://www.cygnusx1.net/supra/librar...be/BE_010.html
i completely removed my Theft Deterrent Computer, as there is no need for it to be in the car if i've bypassed the alarm function!
there is a wire you must cut. it is a blue wire with an orange stripe. cut it near the connector, and make an extension to the nearest ground, and ground it well!!!
once you pull out the computer, and ground the blue wire with the orange stripe, your alarm problems will be solved.
if, however you forget to ground that wire, your starter will not engage when you turn the key. it is the ground for the starter that the alarm cuts to disable it.
edit: to add some more info.
-shaeff
