Aftermarket water temp sensor in upper rad hose - 1JZ
jzxseven
70
south city, nor cal
Whats up everyone. What have you guys used to mount an aftermarket water temp sensor in between the upper radiator hose for the 1J? I remember seeing some pics back then, but never really took a close look. Thanks.
10secdream
Got Boost?
Sep 11, 2007
767
Edmonton, Alberta, Canada
You can get a radiator hose adapter that fits in your upper radiator hose to mount the sensor. I have also heard that drilling and tapping a hole in the water neck works good as well.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
we have those at VEX. I think they should work.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i have a prosport temp gauge coming and the sensor look's like it's the same thread as the stock one.i'm just going to bolt it there,seeing my stock gauge took a poop.
fstlane88
Single time!!
South FL
This it the setup I have with a prosport WT gauge.....
I like it, just need to clean the wiring up a little bit.
