alright guys, well i have been workin hard trin to re-do my motor and set her up right..
when i blew my first gasket i rebuilt the head and put in a mhg, i ran out of money and wanted my car for my b-day (how selfish of me huh) well hg went again, so when i got back to auto class and found out where rebuildin motor's i yanked mine out of my car.
so far i have measured all the bearings with plastigauged, and every thing was inspec.
i have measured the crank and crank looks great.
im going to be using standard bearings, and was really curious what bearings most of you trust, use and where you picked them up at..
i guess now i'll get the to beggin of the thread on why i started this..
my bores look great, you can still see the cross hatchin, and i was measuing them for out of round and look pretty good, almost no taper on the bores either.
so i decided, i'll deglaze them/ hone them and through in new rings, re-use stock pistons and go through all the bearings.
well my question is, what aftermarket rings will fit the stock pistons? i was looking at je rings, but i am not sure about fitment.. there 50 bux or so cheaper then stock rings.
i am also going to be using arp's in the bottom end, and i already have studz for the head.
the main studs seem easy enough to install, but i had a query about the rod bolts, i asked my teacher about removing them, he said it's not hard to do , but would advise against doing it untill new bolts are here (makes sense)
he said install into vise, and hit then center of the bolt with a punch and drive them out.
i guess since im talkin about rebuild stuff here.. i want to get my crank and rotating mass balenced. does the machine shop need the block to do this? and all the new bearings? or do they scale them? and spin the crank on a machine?
