I'm looking to replace the stock coolant temp gauge with an aftermarket gauge from PLX Devices. I already have other PLX gauges, so this should be an easy install into their system.
The PLX sensor appears to be a VDO brand 1/8 NPT fluid temp sensor. I also purchased a 1/4 bspt to 1/8 npt adapter. My plan is to replace the stock sensor with this new setup. From what I've read on this board, there's no better place than where Toyota put their sensor (go figure
My question is: looking at the pictures below, do you think that there is enough surface area exposed for the temp sensor to get accurate readings? I'm guessing that there is, but figured that I'd get some advice from the experts on this board. I'd hate to install this and get bogus temp readings.
