AFR ratio around 10 under boost?
Turbo Habanero
4,229
Tucson,AZ
11.5 is a good ratio under boost.
I wouldnt go any leaner (higher) then that.
14.5-15.5 is good for idle and cruising/normal driving
kikdurazz
what's the birdcage for?
winnipeg
Devin Hutchison;1798714 said:
See my previous posts under my name. I just bought this Supra.
Sent from my PC36100 using Tapatalk
Just a little FYI, People aren't gonna search your other posts for your setup to aid you.
If your looking for answers give a description of the problem and then add all relevant info to car setup to see if they can help or if changes can be made.
10.5:1 is rich but we need to know what you have installed in the car to see if changes can even be made.
11.5:1 is generally what most strive for in terms of power and safety.
15:1 would be way to lean under hard acceleration and grenade your motor.
At idle or light cruise throttle application this would be fine.
I'll provide what I could decipher from that for sale add since your new and I'm bored tonight but as a rule your questions will go unanswered if you don't provide relevant info. People generally aren't gonna do the work for you:
Rebuilt 7mgte with wiseco pistons
eagle rods ACL bearings
Lexus AFM
PTE 550 injectors
3" exhaust
CX racing intercooler kit
IS300 coil pack
MBC at 15 psi
walbro 255 fuel pump
Stock ct26
te72
Classifieds Moderator
6,622
9
WHYoming
Pretty normal for stock ecu setups on our cars, leanest my 1j has ever been on stock injectors is around 12.5:1 under a LOT of boost from the stock twins. 15:1 under boost, is, like others have mentioned... dangerous. Lean is mean for a reason, it melts things. ;)
