AEM V1 on Aristo 2jzgte?
NewGen
799
Norwalk, IA
I've looked all over for this answer and have gotten mixed reviews. Is it possible? From what I gathered I believe you just need to rewire the maf for map and adjust the settings accordingly on the EMS. Any help would be greatly appreciated!
Matt
soapra
860
VVTi'n, CA
www.kaizenmotorsport.com
We are running ID2000 cc injectors at the moment, making 815 whp on E85, So, Yes, it is possible to use 1250cc on that box.(must use high impedance injectors or a resistor box for low impedance injectors) The AEM box will work on Aristo harness with out a problem. Use an AEM 3.5 bar map sensor and keep the stock air temp sensor. works just fine.
