AEM & Power steering
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
Anyone here that runs a AEM ems had problems with there power steering???
Before i switch to a Standalone my power steering was great, Got the AEM installed & tuned power steering went away, Is it a wiring thing? or the pump just when bad or the rack & pinion??? PLease i need input as i dont see any leaks or missing fluid or any noises from the pump or rack...:1zhelp: BTW it's a 92 supra, Don't know if that matters....
Jostar
May 21, 2007
746
Chicago
IJ, This is probably a dumb question.... Where is the PPS ecu located at??? I do have a 1jz & it did have Nice steering before, Now it's hard as a brick...
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I think I might have a non-pps pump in my garage if you want/need it. Only thing is I'm in MN for the week...
Jostar
May 21, 2007
746
Chicago
I have a 1jz... WHat does the 1jz have??? PPS or normal??
There's a Valve mounted onto the rack and a control box inside the car.
The box get's a signal from the Speedo/ECU that tells it how fast you're drive the box then tells the valve harder/softer based on road speed, I'm guessing during the AEM install that signal wire has been cut/not connected.
Jostar
May 21, 2007
746
Chicago
Thanx IJ, I am gonna go back to Sound Performance & ask them to fix it as it happened when they did the AEM & everything was supposed to be running great, I spend Good!!! chunk of money (4.5K) on the AEM & tuning...
