aem ems=no isc valve?
figgie
Twin Cities, Minnesot-ah
suprawalt;985518 said:
just wonderin if i need the isc pipe going into the intake when i have my ems hooked up?im runnin the ems with map sensor.thanks walt
it depends.
If you are still using the OEM AFM, no you can not. If you went with a MAP sensor + IAT, then yes you can.
Doward
4,245
Alachua, FL
If you are using the stock AFM, then you can not run the ISC pipe open to atmosphere.
If you are running speed density mode (MAP + AIT), then yes, you can.
Listen to Figgie - he knows what he's talking about ;)
suprawalt
62
seattle
www.suprawalt.com
thanks alot guys thats all i was asking for.yes im runnin the map sensor+ait+aem ems.
