adjustable inlet turbo
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
woke up this morning and a thought popped into my head. tell me why it won't work.
would there be any plusses to designing a turbo with a spiral shuttered inlet that will open and close with the speed of the engine?
a smaller inlet would allow less air while a bigger inlet = more air. this wouldn't have any effect on spool up time though, because that's dependent upon the hot side, right? never owning a turbo, im not sure if this is right or not.
im trying to find pics but can't think of a name to search for.
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
Keep your day job...:evil2: :nono:
Supracentral
10
Clip said:
i asked why it wouldnt work, make it constructive criticism.
What possible potential benefit could creating a restriction or vaccuum on the inlet side make?
It's not a question of it "not working" it's a question of "it doesn't make any fucking sense to start with"...
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
if thats the case then why dont all aftermarket turbos have a monster of a compresser housing there has to be some benafit to a smaller size.
Clip
Oct 16, 2005
2,738
9
Virginia
so should i be thinking about the outlet side, or are turbos designed to flow as much air as possible? if i owned one, it would be easier to conceptualize; i dont fully understand why porsche designed a turbo that would adjust in one way or another to be more efficient.
lagged
1991 1JZ
new rochelle
i think you are misunderstanding a few concepts of basic turbo charger operation.
try the howstuffworks website or wikipedea and read up on how turbo's actually work.
or if you are near a bookstore, pick up maximum boost by corky bell.
Clip
Oct 16, 2005
2,738
9
Virginia
thats about it. ive been looking for maximum boost for a while, cant find it anywhere around here. gettin ready to order it online
its a good thing im NA, or id have already killed myself :biglaugh:
MRSUPRA
838
Maryland
I think what Clip is trying to say is to have a variable inlet side to the turbine housing. Maybe thinking that (a smaller opening) would increase the exhaust gas velocity hitting the turbine wheel, thus creating faster spool-up at low RPM's. And then the inlet would open up at high rpms's to reduce back pressure. Sort of like an adjustable A/R.
