A340E Flow direction
blk92suprat
J Zizzle
Jul 6, 2008
453
USA
At which side is the transmission fluid entering the radiator hot and exiting the radiator cool? Id like to add external cooler post radiator.
Thanks
blk92suprat
J Zizzle
Jul 6, 2008
453
USA
Ok I will get the inline filter. But I want to filter pre cooler so which tranny hard line is the in and out?
blk92suprat
J Zizzle
Jul 6, 2008
453
USA
does anyone know off hand which line is what at the radiator? Is the driver side the hot and passenger side out is cold? Or opposite? Thanks
blk92suprat
J Zizzle
Jul 6, 2008
453
USA
hvyman;2057094 said:
You would be better off just doing external and using a magnafine filter inline.
I got this filter on order. How often do you change this external filter and the oem filter in transmission pan while in conjunction? Do you have this filter before of after your external tranny cooler?
Does not matter where you place it.
The filter on the trans is not the type of replacable filters. It is replaceable but it is just a metal screen.
