A340 transmission fluid flow direction?
BLACKCAT
185
BHG
Thank you Ian.
The lines are pretty close to the exhaust pipe so will wrap them with some heat insulating tape in that area.
Merry Christmas & a very prosperous & safe New year to all.
Very welcome BC!
BioSkyline: The question wasn't "does it make a difference?"
If you don't know please don't post in Tech, if BC was plumbing in a remote filter direction of flow is important due to the antidrainback valve in most filters.
bioskyline;1653344 said:
ok the question was unclear, and i actually have never seen a remote filter for auto tranny before.
Quite a few of us run them.
BLACKCAT
185
BHG
I plan to install a transmission cooler but cannot decide whether to run it as a standalone or use it in addition to the existing radiator cooling.
The only thing that worries me in using the radiator is if it develops a crack, & coolant finds its way inside the transmission fluid its goodbye transmission (2K worth), as its 2nd hand & I dont know its history.
What is the possibility of this or am I just being paranoid?
The Mk3 Cooling system doesn't have a lot of overhead at the best of times due to the small frontal area, I tend to use standalone A2A coolers for the trans, ran a fan forced one at the back of the car for awhile.
BLACKCAT
185
BHG
Due to space limitations I can only fit something like a Derale 17" rail cooler on top of my intercooler.
I think this is a good spot as it will sit right behind the grill & receive maximum airflow without obstructing the intercooler at all.
For the Chev I ended up with 2 of the bigger DC coolers in series between the AC and Rad, temps were fine and keep in mind it's only a bypass circuit so there's minimal pressure/flow in there ;)
The Mk3 makes cooling "interesting" to say the least!
