Hello all, I'm looking for some advice on a few things, but first a background on my car: 1988 NA/AT converted to Turbo 5SPD using a JDM 1990 7MGTE and JDM 1991 R154, with a remanufactured 1991 7MGTE/AT ECU and NEW wire harness. I have been running 4 quarts of Mobil 1 10-30 (Group 4) and 2 quarts of Valvoline Max Life Full Synthetic 10-30 (Group 3 High Mileage) for 5,000 miles now, and am going to drain a quart of oil and add a fresh quart of the Group 3 High Mileage oil to go till 10,000. I have been using my A/T cooler section of my radiator as my oil cooler, but have not seen any problems with doing this yet. Got a new HG as well about 10,000 miles ago, but was installed by a VERY competent Supra owner.
Well, after retightening my turbo elbow bolts for a second time and installing heavy duty lock washers to prevent the problem, I notice a slight tapping noise from under the hood. First thought: Please God don't let it be rod knock. I am running 7PSI through an NA exhaust (Had to shim the wastegate to achieve this through that pea shooter exhaust), and I have been losing oil. The engine looks spotless, but the transmission is completely drenched in motor oil, not transmission oil. The inside of the bellhousing is drenched in oil as well, but the flywheel is also spotless. It makes this noise under any and all conditions, Cold Idle, Hot Idle, WOT, Cruising.
The rear main seal is brand new, I did a wet install, and used the old seal and a rubber mallet to get the new one into place. I know I have a boost leak, but am having one hell of a time finding it. I'm going to be taking off all of the pipes and doing a complete teardown of anything and everything that doesn't have a gasket to see what the hell is going on with my engine.
So here's my oil pressure situation according to the gauge:
Oil pressure at first start up takes about 6-7 seconds to register only when cold.
Oil pressure at cold idle is about 35PSI.
Oil pressure at 2k RPM cold is 40PSI.
Oil pressure under normal cruising condition is about 25PSI.
Oil pressure at hot idle is about 10PSI
Oil pressure at WOT is 37-38PSI.
The turbo has little shaft play and next to no radial shaft play, and boosts fine. I have no engine codes, and no loss of power. I realize that the gauge isint the most accurate gauge in the world, but it does seem a bit low for 10-30 doesn't it?
Sorry for the long post, but I want to give as much information as possible. Let me know if you need more. Any and all help is appreciated. Thank you.
Shawn
Shawn
