So the car has been completed with installs of new parts.
Gone to a GT35R on T4 setup
With HKS VPC/safc combo
Previous setup was a Lexus afm/ safc
Ct26 60-1 with 10 degree clip
Mods on the car:
550 injectors
walbro 255lph pump few years old now
AFPR(have to check what pressure is at)
J tube block off
no egr
3 inch exhaust
2.5 intercooler pipes
Spearco intercooler
GT35R
T4 manifold
with external gate
Aem uego WB
Now we got the car running and want to get it out to the dyno for tuning but to do that I have to drive about 1 hr outta town.
When I drove the car home from the shop yesterday the car idled at around 14.5 up to 15 on the WB when it was warmed up.
Cruising home in light traffic the A/F were hovering around 15-17 with light load. Alot of times it would just go to the extreme lean and no numbers reading.
when I got on the hwy at 23-2500rpm it was 15 and beyond generally not reading just the 2 lines on the wb in the red. This is with 10% throttle applied reading off the safc to keep a steady RPM. If you give it a steady tromp on the gas more then 30% throttle it starts to go richer between 12-13.
Obviously this had me worried on the way home. Should the cruisng A/F not be closer to 14-15 as the ECU is doing all the correcting?
1. First time with a WB in the car so I have no idea what is normal to see on a WB while driving in traffic and on the HWY/
2. All the settings on the safc are from the last setup and the vpc is newly added.
So should I:
A: set the safc to 0 correction on lo/hi throttle and vpc to 1200 on all nobs and see what it does at idle
check fuel pressure and make sure it is set to base(checked tonight with vac line on FP is at 32-34psi)
B: just leave things as is and drive out to tuners
C: tow the fucker out there (which would cost a fortune)
If you guys need more info let me know I just wanna get this thing running right before doing power runs.
Mods on the car:
550 injectors
J tube block off
no egr
3 inch exhaust
Spearco intercooler
GT35R
T4 manifold
with external gate
Aem uego WB
So should I:
