A/C fan speed help
Levi Mangiaracina
14
Columbia, TN
I found the replacement part on rockauto.com. Looks like some solder might fix it. Is this resistor under the dash on the right or left? I will do some looking around and try to find it. Thanks for the help!
modmonster2008
mod crazy yo!
Sep 9, 2008
1,051
Seattle, WA
The blower motor resistor is the little sensor looking thing with a bunch of coils wound and soldered on, doesnt look like solder would actually melt on it as i've tried it before, its much better to replace so you would not have to worry about it in the long run :)
Levi Mangiaracina
14
Columbia, TN
Thanks all, found it! On the passenger side toward the firewall.
bioskyline
1,236
powell river bc
yep thats the piece. the low is the highest resistance wire and so breaks first. a rejoin is just a band aid fix, it will break again. a new one will last much longer.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
That's the one. You *can* solder it, but I've never had any luck making that last more than about a year. They aren't expensive anyway.
Part number is 87138-24030, cost should be about $25 with a decent discount from any of the places that likes us.
