"927mgtePat's" New Build Thread!!!!
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
927mgtepat said:
Hey, you need to clean out your mail box, cant send you any more PM's
:aigo:
Im sorry bro, i didnt realize it till i tried to pm you and see if you got my old Pm. lol and it wouldnt let me send cuzz my box was full haha.
anyways you know anyone trying to get rid of 1000 cc inj.
crazysupra2JZ
740
Georgia
927mgtepat said:
What Turbo are you running?
XSPower T70
i didn't continue with the 7M, i swapped in a 2jz, which i used this turbo on it. i was amazed by it, gonna get another one next year when i do the swap again
927mgtepat
653
Brighton, MI
Just figured id post up some new pictures of the progress. The engine in the car is a mock up so I can dry fit parts and build the front facing intake manifold and exhaust manifold for the new turbo.
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
nice! did you get a whole new block, head, brake stuff and everything!?!?!?
that engine bay looks like it will look sweet...
i wonder what it would look like if you painted parts of your turbo that candy apple red... beautiful color.
927mgtepat
653
Brighton, MI
xxxotiknightz said:
Looks nice. Did you have all the aluminum parts blasted or painted?
Titus
Everything was blasted. I'm actually going to be selling those valve covers, I got custom CNC ones coming that I designed to hold the 1J coil packs. I'm getting those Candy red also.
927mgtepat
653
Brighton, MI
Hello all, just want to post an update of my progress, I have been doing research and collecting parts for the engine over the last couple of months. I finally sold my old short block and was able to finish buying the parts needed to get my new engine together. Here is a list of stuff I got so far for the build:
92 7MGTE Block ( Stronger Main Caps)
7M crank
New 7M oil Pan from Toyota ( Pan is Getting Extensions Welded on it to hold more Oil)
Eagle Rods
JE Pistons and Rings (.40 over)
Clevite 77 Main and Rod Bearings
Toyota Thrust Washers
ARP Main Studs
ARP Head Studs
New Water Pump
New Tension Pulley
1JZ Coil Packs
Aftermarket Adjustable Cam Gears
Garrett GT45
Comtech 1.3mm Metal Headgasket
Supra_Villan
needs his car done
Nov 10, 2007
662
Wellsville MO
crazysupra2JZ;750358 said:
XSPower T70
i've heard horror stories about the longevity and functionality of those turbos, is that why you are replacing it next year? how long have you had it, any issues?
927mgtepat
653
Brighton, MI
Haven't ran it yet, but i had a local turbo shop tare it down, They checked it out and balanced it. A buddie of mine is running one and has put over 10,000 miles on it with no problems.
