Ok lets do this again, last year I was supposed to dyno the supra but the night before the dyno I did a compression test and it had low compression of 75psi in one of the cylinders. So the dyno was cancled. I bought a used built block from one of the members on here. The block was built by L&R performance out of Santa Fe Springs, California. I also bought a hks 2.0mm stopper head gasket and the new design Tial MV-R 44mm wastegate for the setup. Hopfully things work out good this time so I can dyno the supra this year. Wish me luck. Here is the link to my last build thread..............
http://www.supramania.com/forums/showthread.php?106958-MK3-Supra-T67-Build
Here is my mod list, enjoy.....
Blue print block
eagle rods
wiseco pistons .40 over
HKS 2.0mm stopper head gasket
Arp main bolts
Arp rod bolts
Arp head studs
new modified oil pump for more flow
new water pump
all new gaskets
eibach springs
hks turbo timer
AFC 2
FMIC with 2 1/2 pipings
hks ss bov
SX regulator kit with fuel gauge
comp turbo T67
Drewgo turbo manifold
Tial MV-R 44mm wg
rps clutch kit
alluminium flywheel
Chrome mk4 wheels...235 in front ....275 drag radials in rear
boost gauge
egt
255fp 12 volt rewired
Custom magnaflow 3" exhaust system
aem wideband
Ngk Blue wires
680cc
hks vpc
dna mbc
4/23/11.........Today was nice day in Michigan so I decided to start working on the supra. Pulled the motor out, separate trans from block and motor onto the engine stand.
More to come...........
Blue print block
eagle rods
Arp main bolts
Arp rod bolts
Arp head studs
new water pump
all new gaskets
eibach springs
hks turbo timer
AFC 2
hks ss bov
comp turbo T67
Tial MV-R 44mm wg
rps clutch kit
alluminium flywheel
boost gauge
egt
aem wideband
Ngk Blue wires
680cc
hks vpc
dna mbc
