90' GTE into 87' car
gatorm
Centerville, Tn
So, real quick yes/no question. Can I put a '90 engine with intake/injectors/etc into a '87 and it plug up? If not, I assume all my '87 stuff will convert from my engine to a '90 engine, right?
Thanks....AGAIN!!! lol
Beer for everyone that answers
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Yay beer;) yes u can no everything wont plug right in... I put a 90 engine in my 88 ... there were a couple sensors I had to change such as the coolant temp
Sent from my C771 using Tapatalk
No Beer For You!! ;)
gatorm
Centerville, Tn
Ok....now this. The engine comes with a 90 (of course) ECU and harness. Can I install the entire thing? The 90 is an auto trans engine/ecu but its going in a manual '87.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
I put an '87 GTE into an '89 car. I used the '87 electronics and wiring harness.
The ABS didn't plug 'n play, and there were a couple of small issues, but it worked.
If you're putting the '90 engine in and using the '87 electronics, then you'll need to change up a few things. Injectors will need different clips, but those can be done.
