$89 to replace a passenger window motor...
CampbellsChunkySoupra
best be eating your soup!
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
Toyota of Des Moines quoted me at their $89/hour labor charge to replace my passenger side window motor. my door is disasembled already and i have the new motor too. its just ridiculous to replace it. i dunno, i might just give in and pay the price to make my day not suck.
:icon_conf
i dunno. im at the point of just eing way to pissed off at the window. its hard as hell to get at and i dont want to have to disasemble the entire door tray assembly and pull the window out and the list goes on.
raped by the dealer, once again!
-Tyler
havocatl
Boost get's you Laid
Apr 12, 2005
45
Atlanta, GA
I replaced my drivers side power window motor last summer... it was a PITA... but, 2 hours later it was done and I only spent $20.
toyo4life
238
Manchester NJ
Are you replacing the motor and regulator. either way its no more than 30 minutes once you have the panel off. You have to remove the reggulator from the door to install the motor.
Two things to watch out for , Unbolt the window glass first and pull it up to the highest position, the use a block of wood through the door the hold it there. then unbolt all the reg. bolts I think there 6. Carefully unscrew the motor from the reg. beware of the tension spring when you pull the motor the reg. will snap shut and loss of digits will insue if not careful.
Mrbaboon
277
Victoria, BC
Once you learn how to take the panel off its actually one of the easiest things to do in the car. Really. I think installing speakers might be harder.
Here's one for fun:
Try to install your turbo oil feed line into the block with your turbo already securely bolted to the exhaust manifold (using the stock lines). Now THAT was fun. Fucking crush washers.
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
well. ive got the panel off right now. i have unbolted the glass and pulled it up like u say and put wood under it to hold it up.. i just cant get at the window motor. it appears as if the screws that hold it all in are facing the inside of the car so i cant get a screwdriver on them. maybe ill have to take the whole assembly out. unfortunatly, the haynes manual does not offer much help in this process. ill try to tear into it tonight.
thanks.
oh, i live in iowa, there aint no supra owners here :D
toyo4life
238
Manchester NJ
thanks.
yeah sorry I Kinda ommited the part between the six bolts and the three screws for the motor. ......Remove the entire assembly from door. Thats why i was asking about replacing both parts at once since you have to remove the regs. anyway. Goodluck.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
why not just fix the old motor is easy as pie most of the time all you need is gule
cause most of the time the magnet's fall off the side of the motor can and you just glue them back on and wow it works again
sh-zaaamm sh-zammm
ps pulling the glass make's easyer instead of leavn it in the door pluse you wonte scarch ti wel pulling out the window reg
good luck
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
ive changed window motors before. the one in the supra is alittle difficult to get at when u have to take out the whole assembly. with most cars, u can just reach in, unbolt the motor and connections and put the new one in.
on a side note, ive got a friend that has a shop that will help me with it.
lumpy
Iowa
:wavey: Quad Cities here. (Muscatine) I work at the Toyota dealership here too! :biglaugh:
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
:D lucky...
so i took it into the local shop, they had it done within 30-45 minutes. ended up being $63.30 after all was said and done. it was pooring hardcore today in iowa too. so i needed my window up asap. it beats driving the 30 minutes to toyota of des moines and then waiting awhile, and then getting charged a minimum of $89. so i think i done good!
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
hah, it was raining SOOOOOO HARD in teh des moines area ALL day. i couldnt last another day with a 2 inch crack at the top of my passenger side of my car. i didnt have a garage to replace it in. im a fulltime student and a part time worker so time is limited.... oh, i also have a FULL TIME girlfriend, so crap.. i have NO time.
oh, im not of legal age to drink beer. :D except for on the weekends.
