89 Supra Spindle/Rear Axle/Wheel Hub Nut Reusable?
Nougie
28
CA
Ive searched and have found one thread that says it is usable. From other sources ive looked at , i got no true and final answer.
Any imput is greatly appreciated!
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I've re-used it without any issue. There is no reason that you wouldn't be able to, it is simply a nut (i.e. it does not deform when installed)
te72
Classifieds Moderator
6,603
WHYoming
As always, the TSRM is quite handy in cases like this. Exploded views tend to point out parts that cannot be re-used, with a little diamond beside the part number if I remember correctly.
Cotter pins can be reused (you really should replace, but I've reused them forever because I don't mangle them on removal)
