88 supra with cracked cylinder head... what do i do now
88SupraTurbo
87
while replacing the head gasket on my 88 supra turbo, i see that everyhting looks good until i take a look at the removed cylinder head.... #4 cylinder has a 1cm crack.... FU(K. I dont know what to do... is there any way i can get around replacing the complete cylinder head (i doubt there is)? any helpful information or your past experiences with this can help, also, what could of caused this, i just bought the car about 3 weeks ago so i doubt i had anything to do with it. thanks.
88SupraTurbo
87
Could be repaired but it'll probably cost more than another head as they have to remove the valve seat weld it recut the seat pocket and press a new seat in then surface the head and grind the seat!
Blue87T(Dan)
St. Clair Shores, MI
You should be able to find a decent head for between 200.00-400.00.
Put an ad in the WTB area.
Also check SF. I have seen a few on there for sale.
Unless you know who you're buying from, always use Paypal funded by a credit card. It gives you the most security when dealing with someone far away that you don't know.
Dan
