88 Supra with 1jz swap vs 87 Mustang Coupe with 351w
Status
Not open for further replies.
Mustangs>Supra
19
Chattanooga
motors are in good condition
351 was pulled out of a truck, when we had the intake and all off it looked almost like a new motor, real clean sidewalls etc.
carb is only a holley 600 vacuum secondary, but it does ok
Island_Yota
264
Vancouver Island
Foxbody's are around 3200 pounds with a 302, dont know what they weigh gutted, pretty sure the lightest ones were the 4cyl Coupe's, I hear they were close to 2900.
I say it depends on what gears/trans in both cars and really on how the engines are built. That said a Straight line isnt where the Supra shines.
Mustangs>Supra
19
Chattanooga
It WAS an 87 4 cylinder coupe... has a 351 and t5 swap
aod is gone and that takes weight out also.. the auto trans weighs about 160-200 pounds
all interior is all there, good daily driver... but engine bay and all is stripped. no air, no p/s, none of that stuff....
alternator, water pump, and crank thats it
Island_Yota
264
Vancouver Island
So with the added weight of the 351 I really dont think it weighs 2700 anymore?? I could be way off though but I dont think it could be 2700 with a 351 under the good because I do know a 351W weighs around 530 pounds with out accessories. Depending on what year 351 you have it might not be as quick as I think, some made as little as 170hp, most make 210hp-220hp stock, some made 250hp, with a decent build(higher compression, cams, aluminum heads, 650+ 4 barrel, headers) they make around 300hp.
Regardless, I think it will beat the Supra in a 1/4 mile.. 351 probably has more torque, Supra could weigh anywhere from 3450-3750 without a driver depending on the model, could have any gears, tires.. and most important.. the driver.
shaeff
Kurt is FTMFW x2!!!!
11
Around
Yeah, bench racing sucks. Take it to the track, find out. Thread closed.
Status
