88' supra rolling shell, doesn't move!!! PLEASE HELP!!!
mk3rick
4
palmdale ca
Hey whats up my good friends on mania!
I have a minor problem, my 88' mk3 supra rolling shell doesn't wan't to move a inch at all! :aigo:
I want too know what it is and why??!
I called Driftmotion and they told me it could be the rotors with all that rust or my E-brake is locked?
I checked my E-brake and its not that, my rotors also and they rotate 100% front and back...
I really want to know some good advise so I can fix the problem before I do my 2JZgte swap. PLEASE HELP ME!!
Nolie I'm really worried about this problem!
send me a link of some info or something!
THANKS FOR VIEWING!
Backlash2032
1,823
Nebraska
If all the brakes spin freely then when you put wheels on those should spin freely too.. so you're either not trying hard enough or hitting something..
Sent from my ADR6425LVW using Tapatalk 2
mk3rick
4
palmdale ca
Like today I was working on the supra and checking out the brakes and rotors, and all the rotors spin perfect , and yes the emergency brake was down , and still no movement?
Any other digestion.?
Hotwheelsjr
146
Surprise AZ
'Rolling shell' -- I assume no engine or trans? Do your wheels fit properly? Do you have over sized brakes? If everything moves freely without the wheels on, good chance the calipers are caught on the inside of the wheels. Did it used to move and now it doesn't? What has changed since the last time it moved?
te72
Classifieds Moderator
6,626
9
WHYoming
Try pushing harder.
In seriousness, do the wheels spin freely once put on? If you're trying to stick a high offset 15" wheel on your car, that's going to cause problems...
te72
6,626
9
WHYoming
jetjock;1851317 said:
I'm trying to digest why you'd need advice from a forum about this...
Poodles;1851406 said:
It's a fat ass car...push harder.
Well, we can officially add "jelly beans" to the things choked on when reading this forum... combine those two posts together, and things get kinda funny!
