Well thought I would do a big update. Few more runs on the dyno and was able to squeeze 420WHP out of it. Threw on the slicks and headed to the drag strip. Did 11.81@ 117. Made 18 runs that night and blew the felpro head gasket hard core. It egg shaped all 6 cylinders.
Got the car towed back to the shop and pulled the head off.
Original plan was to check and clean the block, re deck the head and put on a HKS metal head gasket with new ARP head studs. Cleaned the old gasket material off the block and ended up block was pitted and was not going to seal on a metal head gasket most likely. So I pulled the motor and ripped it down to a bare block to be decked and honed. Full rebuild as follows
Deck Head, Check valve's/seats, replace valve seals
Deck Block and Power hone
All oil and coolant passages will be cleaned out in block
All new expansion plugs
Re use pistons and Rods
Clevite 77 STD Thrust, rod, and main bearings (old 153k mile old bearings looked great, could get away with reusing them but going to replace them anyways.
NPR Rings
OEM Aisin Oil Pump/pick up
OEM Toyota Timing Belt
Front/rear main seals
All Gaskets
HKS Metal Head gasket
ARP Head studs
The machine work will be done by my brother and I at Accurate Performance Machine here where Dana Westeovers Intake Manifolds were flow bench tested. Whole motor will be built and blueprinted by me as well.
Got the motor prepped for the machine work on Monday. All expansion plugs knocked out, All gaskets already removed, Front cover bolted on to be decked with block, All oil and coolant galley plugs have been removed, All thats left is to pull the dowel pins out of the block for the resurface. There's a nifty tool for that at the machine shop.
Thanks,
Devin LeBlanc
