Ok...I've exhausted all my ability to search and test. I think i've tested everything or replaced it...I've searched several different ways and found others that have similar problems, but did not see any solutions...their threads just seem to die....here goes...
It's a 1988 GE, all stock. I got the shell with no engine or tranny and bought a known working engine and tranny. I had to swap the wiring harness as the engine came with an 89 harness and my shell is an 88. I had to swap the distributor plugs and the injector plugs as the engine is a CA spec engine and the injectors are a bit different. I put in a brand new battery that cranks the engine just fine. It ignites and seems to start to run, then just dies. The fuel pump is pumping correctly, it seems that the cold start injector is doing it's job. I have checked the injector relay and it tested good. Tested continuity to the injectors, and that's fine. I've tested the power to the injectors with the ignition switch on and I get 12 volts on one terminal, then I get 10.5 volts on the other..I got a noid light and it did not show any definitive answers. I seemed to get a single pulse of the light on #3 and #5, but nothing on the others, and this only happened one of the 4 or 5 times i tried it...this is not right. I've swapped out the ECU and same thing. I swapped out the fuel pump relay, same thing. I've swapped out the MAF sensor, same results.....tested each item i pulled and tested the ones I swapped in, they are all good components....I'm stumped....anyone have a clue what to check next or what is going on?
