Hi,
I have installed a 7MGTE 89mod in my 87mod chasssie, and I have e few questions. But first, I need to say that I am going to use a standalone ECU (EMS), so I am aware that I can not use the 87 mod ECU on the 89mod engine and so on. But my questions is:
- If i use the 87 mod engine harness, the connectors inside the car will fit 100%, but is there any difference on the connector on the engine?
- If i use the 89 mod engine harnes that came with the engine, the connectors inside the car would not fit, but of course all the connectors on the engine does. How do i rewire the connectors in the car? (if this is the only option)
So, can i use the 87mod engine harness (that would fit the car) on the 89 mod engine, and as I said before, I have a standalone ECU/EMS, so that would work anyways..
Regards, Daniel..
Regards, Daniel..
