'87 Drag Car 7M awesomeness
Albert
May 13, 2009
1,710
Tempe, AZ
The first attempt didn't work...
I'm working with him on a new cam pickup setup, crank pickup. The fuel rail I made him is going in along with the big injectors and fuel pumps... Got the direct port nitrous fittings installed into the manifold. Also working out the design on the turbo return line, so when it does start it can idle longer than 5 seconds at a time.
A LOT of work is still needed to get done and like Steven said it's prioritized on when he has the time to do stuff.
Patience, maybe by the end of the year he can get a video of start up and idle and a good walk around.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
AGlobalThreat;1965454 said:
I've been wanting to do the exhaust out the top of the hood like that. Can you please post if there's any issues for example with heat on the windshield or hood?
Looks great as always.
run it out the fender
flashes oh fire when you are racing is not what ya want
Albert
May 13, 2009
1,710
Tempe, AZ
Dyno numbers in
stevenr816
932
Phoenix,AZ
Well I guess it's time for a reply. Cars constantly taking 3 steps forward and 10 back. But so far the last couple weeks have been forward.
Had a small garage fire, and ended up getting rid of the old body as it would have been time and cost effective. Picked up a straight 87 for $400
Pulled all the frames to swap over
Now my old 87 was a garage mantelpiece
New car
The stripping begins
Started cutting some spot welds to make the body look better
Started pulling battery tray
Cut unnecessary stuff off the cross bar which will be replaced when the cage is made
Cleaned the whole bay, was probably the worst one I've seen you can compare it to the sub frame
stevenr816
932
Phoenix,AZ
I ordered an excessive amount of stuff this last week, and had a decent bit already
Ati converter 4500 stall
Picked up Alberts old seats
Canton filter head and wix racing filter
RK poly bushings, why orange no idea
Quick release hub and wheel, wheels being sold and going momo
Permacool dual head
Albert and I made a -10 rail
Polished and weld in fittings, will be anoed black
Direct nitrous stuff, electric water pump
Decent size tranny cooler with fan & shroud
Stocking up on ProEFI
Cute little flash drive for the logger
Mocal oil thermostat
Bbk all finished
Tb, oring groved, mached for seals, and ball bearings, polished
New lokar locking Trans dipstick
