'87 Drag Car 7M awesomeness
crisp
existentialincrementalist
May 25, 2007
1,785
Ohio
I'm just catching up on this thread... and noted the latest TURBO ACTION. (Still looking for my brains... I think my ceiling needs scraped off this weekend...)
-crisp
stevenr816
932
Phoenix,AZ
Been busy with work and buying a house and moving. Got the car on the ground ready to move aswell as some other stuff. Solid bushings in.
Rear spindles together. New spherical bearings, wheel bearings & seals, poly trac bar, Evo/sti setup.
Got my tranny tunnel hammered out, tranny mount made aswell as my driveshaft
Steel, 2.5" DOM, 1310 ujoints, only 4.5lbs heavier then aluminum.
Tranny mount tacked up
Albert
May 13, 2009
1,710
Tempe, AZ
Looks awesome!! Coming together nicely.
When is the manifold gonna be made so you can mount on the turbo!?!
Weld up your FFIM!!!!
stevenr816
932
Phoenix,AZ
All that stuff will be after the move.
Everything's ordered to start the engine once we move. Got some NDC bearings, brad penn break in oil.
Just need to put it all together and finish wiring.
doonsuka
107
AZ
YES Dude. I've never even seen that car sitting on it's own weight before. That tranny mount looks sweet, did you make two? :naughty:
stevenr816
932
Phoenix,AZ
There's a distributor here local called world pak. That's the sticker on them, though I did not personally order these.
All the clevite bearings I've ordered in the last month have all been NDCs
IanC
101
Maryville, TN
WorldPac is owned by CarQuest. They deal in OES (original equipment suppliers) parts. You can go to any CQ and get original parts for most imports. Pretty cool setup.
stevenr816
932
Phoenix,AZ
After making Alberts exhaust, he made this for me. Got the trigger wheel from trigger-wheels.com. Was a 36 tooth and had to cut 24 off to make it a 12 tooth.
It is adjustable if needed to help dial timing in outside of the ProEfi.
Will get a pic of the actual bracket tomorrow.
