87 2JZGTE swap
steveyblack
529
Nj
just need the pulley now, Last part I need (except fluids)
Painted my crash bar, I will never see it but it beats it being full of surface rust
USDM cams
Old cam, See my reason to get new cams? =D
Water pump, Timing belt/tensioner/idles, cams, and some other little work will be done with this week coming up. I hope to have my harness before labor day, that way I have a 3 day weekend to drop everything in. Im making some parts look purdy too =D
steveyblack
529
Nj
How she sits right now
new cams
crank tdc
intake cam lined up
ex cam lined up
which hose is the inlet for the heater core and outlret?
ghetto fix, i hope it works
steveyblack
529
Nj
viper92086;1418731 said:
go faster!!! lol i want to see this thing done
This weekend im pulling the 7mge out, and maybe even putting this bad boy in. The harness is done, Dr Tweak is the man for making my harness look new. Im hoping to have it running by next week. Im waiting on 2 gaskets at the moment. My goal is to have it started up and mayne even running on the streets before october 9th. And all the bugs out by the supra meet.
I cant wait to see your car! that thing is a beast
MA702Tone
55
Tennesse
USDM cams
Looking at the picture of the cam :nono::aigo:, I wonder what the rod, and main bearings look like. Also wondering what the bottom of the cylinder walls look like when you cycle the engine?
steveyblack
529
Nj
the bottom of the crank(not the bearing surface) was a little surface gunk, just took a rubbing with a brush to get off.The walls of the cylinder looked good from what I can tell.
MA702Tone
55
Tennesse
The crank did not have any scoring, pitting nor did the cylinder walls? Do you plan on replacing the bearings ( Rods, and Mains )?
steveyblack
529
Nj
They could of sprayed some wd40 down each cylinder, when I looked under the engine and up into the cylinders, I didnt see anything to throw up a flag. I do plan on doing a mild build sometime in the future.
MA702Tone
55
Tennesse
Cool cool.. I am happy for you on your build man!! Hope all continues to go well in your favor: icon_bigg what are your goals for your project?
steveyblack
529
Nj
Thanks! ill break this down by time.
ASAP
Get the car up and running again.
Exhaust
6 months-12months
brakes/rims/tires.
Maintenance!
either find a new rust free shell, or repaint(stock color)
and clean up the interior
12-?? months
Coilovers/sways/bushings
Single. Not to big, T67 or so w/ supporting mods
tranny rebuild
Get the car in 10/10 condition.
Im sure that everything will take me longer then that, ill play it by year.
steveyblack
529
Nj
Rained out on sat, did as much as I could today. I atleast have the engine out and the 2jz is a couple of hours work away from being in.
7m wasnt as dirty as I thought it was going to be =D. Mating the trans up with the engine by tuesday. Going to be pressure washing the engine bay and cleaning the trans too. I hope to have the engine in by thursday
steveyblack
529
Nj
I got the car started tonight, Ran it for 20-30 second only. I was not getting power to the fuel pump, so I jumped it for now. Ill be setting up a relay for it to come on when switched. I needed to mess with the TPS to get it started too. so ill me fixing that too.
steveyblack
529
Nj
So it turns out the oil drain bolt is stipped =[, ill be draining the oil, drilling and re tapping the hole. ill be using a really thick grease to catch and metal shavings. Ill be putting a thread insert in too. Ill be hooking the IC up tomorrow along with the radiator, maybe even take it out for a ride tomorrow. It was raining today so I didnt get any videos
steveyblack
529
Nj
MKIIISupraGuy;1444861 said:
oh god post a vid up when you do take it out...lol. I gotta hear it !!
Will do :evil2: ill be posting videos of everyones first reaction too after I break in my clutch :biglaugh:
