7mgte running rich
7mgt45r
7mgt45r
Sep 23, 2007
60
ATLANTA, GEORGIA
i have 7mgte that is really running rich. i found a broke wire on 02sensor (repaired). Car still running rich chked intake sys. for vaccum leaks all repaired. For fuel management i have safc/vpc. The car cranks okay, but when start you have to keep foot on pedal,but when release pedal car stalls. i have AEM wideband and the car don't start rich, but in about 3sec. it's rich. Tried to adjust fuel curve with safc, but no response. safc will not adjust fuel any more. reset ecu by removing efi fuse(NO CHG). all i have on the car is 780cc precision injectors,fpr,JE piston 040,Eagle rods' port polished head with crower parts, gt45r turbo,-6 in -8 return fuel lines,walboro intank,bosch 044 external,upgraded intercooler, 4inch exhaust. Really don't know the problem really need expert help.i use to be able to adjust fuel with the two pumps but not anymore. No codes at all
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
780cc?
hrmmm, to my knowledge, most people dont go that big unless they have a standalone as the safc has trouble adjusting for such a large injector. Attempt to lower your FP
7mgt45r
7mgt45r
Sep 23, 2007
60
ATLANTA, GEORGIA
IwantMKIII;1061064 said:
780cc?
lower it to what?
7mgt45r
7mgt45r
Sep 23, 2007
60
ATLANTA, GEORGIA
ForcedTorque;1060973 said:
Where is the sensor for the wideband located?
in the dwn pipe. the wideband use to run right. i wired up a hks dli ignition and haven't ran right since. do you think when i disconnected the batt. it reset the ecu and the ecu have relearn the fuel map?
7mgt45r
7mgt45r
Sep 23, 2007
60
ATLANTA, GEORGIA
780cc?
what size injectors do you think i should purchase? i'm looking for 700hp.
7mgt45r
7mgt45r
Sep 23, 2007
60
ATLANTA, GEORGIA
oh ya! My boost gauge its at 10psi when it normally at 20psi when at idle. but i"ve checked for booost leaks
ForcedTorque
Join the 92 Owners Group
6,099
20psi at idle??????????? Surely you're speaking in terms of vacuum.
It does not take the ECU long to relearn. How long has this condition been going on. I would lean more towards something else you did, or a boost leak you missed.
7mgt45r
7mgt45r
Sep 23, 2007
60
ATLANTA, GEORGIA
yes, i mean at vacuum. its been going on for a week
