7MGTE or 1JZ?
Status
Not open for further replies.
Poptart
14
Iowa
I need help deciding, I am planning on doing a swap here this summer and wondering which one can you get more out of in the end?
I am going for about 400-500hp
And also which one is the easiest to drop in?
What do you have to change out on the 2 drops?
ALSO, last question..
If I wanted to do a 2JZ conversion...what do I have to do?
I have 1990 Toyota Supra A/T
Let me know please!
Thanks!
Ken
Ken, there are numerous threads about this subject. Try doing a search for some really good pros and cons for each motor.
I decided to go with the 1jz swap. It's not as easy as just dropping it in. I think the 7mgte would definately be easier for you to do, and I believe you'll reach your hp goals alot easier with the 7m also. As for the 2jz swap, you'd have to have some deep pockets for that one, but the decision is yours. Good luck, Jay
http://www.supramania.com/forums/showthread.php?t=38317&highlight=7mgte+swap
Tanya
1,851
Naples, FL
4M-E
seriously. if you can't bother to search a forum that has 8756837524245315 posts, then you probably shouldn't be building an engine
bigaaron
4,692
Pomona, CA
www.driftmotion.com
supra-addiction
111
hampton
really for my opinion,
7m-gte is easier to drop in, plus from what i see..they make more aftermarket parts for the 7m-gte than the 1jz.
lol, i wish i could have went 1jz or 2jz but the money wasn't right,
and also the money that you will put into the 1jz or 2jz swap you can have at least 4 or 5 different aftermarket parts for the 7m-gte
well good luck on your decision
peace
bigaaron
4,692
Pomona, CA
www.driftmotion.com
All the aftermarket items you can get for a 7m are readily available for a 1jz. Turbo upgrades, cams, cam gears, forged pistons, intakes, injectors, exhaust systems, it's all just as easy to get for a 1jz as for a 7mgte. Actually it's easier to get cams for a 1jz right now then for a 7m. It might be easier to drop in a 7mgte, but finding one worthy of installing in your car is a big challenge.
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
I was hoping someone would ask this question.....no one ever seems to have opinions on this subject! Its like taboo to talk about and stuff, no one will touch it.....oh well.....I'm gonna go pull out some tree stumps with my 7M.
(whips out fire extinguisher) IBTL!!
Dec 3, 2003
6,653
Canada
7M
That is all :D
I got an idea...!
7M pulling up tree trunk torque vs 1J pulling up dandelion torque aka is like a girl and has no balls...:D
Duane
Status
