7mgte no spark?
Aug 12, 2010
347
P.G. County, Maryland
:1zhelp::cry: I was having a problem with fuel cut, and someone suggested TPS, so i changed it, but didn't have the tools to properly calibrate it. I was under the impression that the car would still run is the TPS was improperly calibrated, but it wouldn't run correctly. After changing the tps i found a huge hole in my IC piping, so i replaced all of it with SS pipes. I removed my A/C, and cruise control. This is all i have done since the last time i started my car. Currently the problems i'm having are: Motor is cranking, but won't start. i can smell gas from the exhaust, so i don't think fuel is the problem. I stuck a screwdriver into the #1 plug wire, and i'm not getting spark. For some reason, my Wipers won't shut off. I have the motor unplugged because it was irritating me, but as of last night, they were constantly on, even when switched to the "OFF" position, and the speed would only change by a very minor amount when i toggled the stalk. My main problem is getting it running, but input on the wipers would be helpful as well. Does adjusting the TPS effect my timing? Would resetting my crank timing and resetting my cps help me getting spark? I can't think of anything else other than a bad relay of fuse, but s far as i can tell all my fuses are good.:: angry :::: angry :::3d_frown::3d_frown:
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
check your cps wires, try wiggling them for spark while someone cranks it, or you can do it yourself, jst move it around and then go in and try to start it. i had no spark before and it was actually my cps wires.
and for it to be on it could be your ignition switch thats bad, check the connuity (or however you spell it) and see if its working.
otherwise keep pulling fuses to see if you have a parasectic draw
