7mgte motor removal and replacement
tsparks01
108
queens new york
ok, so now i am given only one optiion, i have to take out my motor and reseal, replace hoses, so does any one know what i have to do or what bolts i have to take off to take the whole motor out, or is it better to remove the gearbox with the engine at the same time. please help its my 1st time
ForcedTorque
Join the 92 Owners Group
6,099
Yes, it is easier to remove the gear box with it.
First, unplug the wiring harness from the ECU. Push it through the firewall, and lay it over on the motor. There are just a few plugs you will need to take loose, and you won't need to take it off the motor yet. Then, pull the radiator and fan. Drop the driveshaft, and tranny mount (support tranny), and then the motor mount bolts. Disconnect the exhaust from the turbo, and at this point you are 95% ready.
There is a 48 (I think) step write up in the tech section. I think it's stickied at the top.
tsparks01
108
queens new york
what do you mean a 48 step.?....so its just the mounts i have to disconnect to loose the motor out, excepting the tranny and exhaust
ForcedTorque
6,099
You'll need to get the radiator and fan out of the way.You gotta break the fuel line lose near the frame rail, and disconnect the clutch linkage if 5-speed, as well as shifter. And, you will need to break a few wires off the harness loose, but most stay on. I know the wiring to the alternator come from the fuse box, and there are plugs that go from the harness over to the igniter. There are a few more, but I'm not exactly sure where. I know there is one wire to the firewall right after it gets into the engine bay from the ECU, and I think the wires going to the fuel pressure relays need to come off. A/C lines need to come loose too. Once you get everything you know needs to come off, and anything else you see that I'm missing, lift the motor slowly to be sure you aren't pulling anything that is still hooked up.
Here's that thread:
http://www.supramania.com/forums/showthread.php?t=423
tsparks01
108
queens new york
do you also know the way to make a non turbo to a turbo..it shld be the same right?
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
search man, ppl gonna start flaming you for asking question thats already been answerd and not searching. If you look on the website in the mkiii reference tech tips section. you will come across a thread showing 7mgte removal in 49 steps. matta fact here is the link http://www.supramania.com/forums/showthread.php?t=423
Almost everything applies to the non turbo 7mge. It tells you exactly what you have to do to pull out a motor. And i already told you what to do to make a 7mge into a 7mgte. matta fact imma help you out again here is another link thats is in the same section right on top where you created this thread. http://www.supramania.com/forums/showthread.php?t=34560
4real tho man just search on this website and you will find all of your answer that your looking for. when you search and cant find it, then you ask. And if i were you i would just swap a 7mgte in if you want to go turbo.
