7MGTE Intake Bolt kit?
toyotanos
What will we break today?
2,844
Coon Rapids, MN
You won't find a 'kit' for our intakes like you would a traditional V-8. You just need a bunch of M8x1.25 bolts of the correct length. Add a couple studs in there for easy installation and you're set!
toyotanos
2,844
Coon Rapids, MN
Those are the only two measurements you need! :D
The hex size just depends on the bolt manufacturer. Factory bolts have 12mm heads, but I've seen everything from 10mm to 15mm heads on M8 hardware!
