7mgte harness
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
I have a 89 5spd 7mgte and I was wondering what yr harness's will work flawlessly with the stock ecu/sensors/etc as I need a new one.
frontierguy25
968
TX
You will need a 89 harness for it to work flawlessly. You can still buy them from Champion in houston. 89 was a wierd year for the MK3.
That is where I bought mine not too long ago.
nick88
JayHall's Hero
May 10, 2009
794
Des Moines, Iowa, United States
Do you want to keep your ecu? Why do you need a new one? Do you have a Soldering iron to fix broken wires?
Any 89+ harness should work as it is grey plug, I think. I have a 88 so i wouldn't know for sure.
Bri7man
Jul 17, 2009
580
Torrance, CA
Alllright, good thing because I was about to buy a 92 harness cause I was told it would work with no problems.
Thanks for the reply
Bri7man
Jul 17, 2009
580
Torrance, CA
It's in really bad condition from the previous owner.
ie melted wires, bare wires, and multiple loose connections with sensors popping off like crazy. I want to have a more solid harness overall.
ilovemysupra
51
Melrose, MN
so... :icon_neut what else was weird about the 89 supras?
Jeff Lange
Administrator
4,919
4
Sunnyvale, CA
jefflange.ca
It would work with most stuff, however a few things would be different, like the knock sensor connectors, and the O2 sensor connector, as well as a couple other things.
Really if you want to just plug and play, get an 89 harness.
Jeff
