7MGTE Forged piston comparison
Status
Not open for further replies.
stevenr816
932
Phoenix,AZ
IJ.;1639588 said:
Contact SupraRich he's about the only person here with actual experience at those power levels.
Already have, he's running the SIP Pistons, but those are $1500 a set compared to the range of $700. Double what i was wanting to spend. I know theres a couple more 7m's out there, Tony at Final Stage as well as others
May be a couple more but the owners aren't active here so all you're going to get is second hand "he said/she said" and not first hand info, for that power level it would be worth picking up the phone and speaking to Tony in person.
stevenr816
932
Phoenix,AZ
I've heard Tony is quite a DB (multiple 10sec 7m's in AZ) when it comes to info but I will give it a try, 3rd time now 2 emails and 1 phone call.
If I absolutely have to run the SIP's then I will :(
Always good to get it direct from someone that's actually done it Steven ;)
I could "suggest" things all day long but it would only be at best guestimations with no basis in reality!
Good luck with the build if you go for it, it's a BIG ask with the 7M platform not unachievable but it's NOT going to be easy and you'll need ultra attention to detail as at that HP the slightest flaw will end in tears.
stevenr816
932
Phoenix,AZ
which is why its planning on being finished by next silv :)
Blackdawg
Taco Soup..my rides
Oct 12, 2010
247
Wyoming
seriously....for 1200+ hp what did you expect? Only been like 2-3 7ms to break 1000hp. If you want that high of horse power...you best be buying the best shit you can lol or things gonna blow up real fast
stevenr816
932
Phoenix,AZ
Thanks for the useless input!
Already have my decesion anyway
stevenr816
932
Phoenix,AZ
TheNewRed;1649926 said:
Speaking of decisions, if i may ask what are you deciding to put the 1000+HP engine in?
Custom CP's like SIP but through my wholesale
CP Customs
SC7470 CP Pistons= $708.00
Ceramic crown coating= $132.00
Moly skirt coating= $132.00
Lateral gas porting= $94.50
Gas nitride ring set= $138.00
9310 steel upgrade pins= $135.00
Total= $1,339.50 + freight
Status
