7mgte ecu power question. what wires to run..
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i have been curious, what pins on the ecu or more so say B1 the body harness connector, would be needed to fire an engine off on the ground or engine stand.. or say a donor shell...
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
very few wires to make it run, here they are
b1 plug
black/white wire(10 gauge) = starter
black/red wire = +b this is the main power wire
black/orange(10 gauge) =needs switched power(this powers ignitor,coil ,injectors)
black/orange(small gauge) = needs switched power
green wire = this controls your cor(circuit opening relay)
C1 plug(near your ignitor under the bonnet should be yellow in colour)
black/orange wire = activating power wire for your main relay
black/yellow wire = constan power for your batt on ecu.
i used these to test my 7m when i stuck it in a 4wd a while ago, i didnt include wires such as water temp or oil temp ,pressure e.c.t cause i gather you only want to fire it on a bench.
youll also need your earths as well.have fun
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
b1 plug
thanx, starting on bench is a plus. but helps other swaps planned aswell.
