very few wires to make it run, here they are
b1 plug
black/white wire(10 gauge) = starter
black/red wire = +b this is the main power wire
black/orange(10 gauge) =needs switched power(this powers ignitor,coil ,injectors)
black/orange(small gauge) = needs switched power
green wire = this controls your cor(circuit opening relay)
C1 plug(near your ignitor under the bonnet should be yellow in colour)
black/orange wire = activating power wire for your main relay
black/yellow wire = constan power for your batt on ecu.
i used these to test my 7m when i stuck it in a 4wd a while ago, i didnt include wires such as water temp or oil temp ,pressure e.c.t cause i gather you only want to fire it on a bench.
youll also need your earths as well.have fun
