7mge w58 transmission with 1jz swap
JB91389
decisions...decisions...
Jun 22, 2006
698
Ottawa
I've searched but I could not find a SOLID answer.
Can I use the 7mge w58 transmission with 1jz swap?
I know I need the 1jz to w58 bellhousing - Driftmotion sells them.
http://store.driftmotion.com/static/i-1jz2jzw58bellhousing.php
My main question is, what flywheel and clutch kit do I use?
Do I use a 1jz flywheel with w58 clutch ?
http://store.driftmotion.com/static/i-1jz2jzw58flywheel.php
http://store.driftmotion.com/static/i-ts3-hdss.php
I also read that you can just use the 2jz flywheel and clutch.
I prefer the first option though - 1jz flywheel with w58 clutch as all the parts are sourced out already.
Anything I am missing?
Thanks!
te72
Classifieds Moderator
6,625
9
WHYoming
Flywheel is engine specific, clutch parts are transmission specific. ;)
destrux
1,183
10
PA
Easiest way to mate a 7MGE W58 to a 1JZ...
~$300- 2JZGE Bellhousing (93+ supra non turbo or 92+ SC300)
~$60- 2JZGE clutch release fork
~$200- 2JZGE flywheel
~$400- 2JZGE racing clutch kit (stock is too weak, buy a good one from ACT, Spec, Comp, or another reputable place)
~$30- Manual trans flywheel bolts (a/t bolts are incorrect). driftmotion.com sells ARP bolts that are less expensive and better quality than OEM. They are also reusable, and OEM bolts are one-time use.
If you have an alloy plate W58 the front bearing retainer might be shorter than the 2JZ release bearing was designed for and you'll have to use a 7MGE clutch release bearing if that's the case (you'll need to bend up a custom retainer clip to hold it to the fork).
Also wanted to add that a 1JZGTE flywheel won't work, it's designed for a "pull" type clutch, the W58 uses a "push" clutch. A 1JZGE (non-turbo) flywheel would work, but they are the same as what I listed above.
Roger UK
75
Newcastle
As you seem to know what you're talking about destrux, hope you don't mind me asking . . .
I'm fitting a 2JZ-GE from a Mk4 Supra to replace the 7M-GE in my Mk3 Supra
Am I right in thinking that as long as I fit the bellhousing from the Mk4's W58 to my gearbox it will all mate up correctly? (been offered one for $50)
And should I use the clutch and release bearing etc from my 7M-GE or the 2JZ-GE?
I'm trying to come up with a definitive list of exactly what works and what parts you need to do this engine swap, as a lot of people either seem very vague, or are fitting aftermarket parts due to upgrades or mods (keeping mine as stock as possible) . . . when I've eventually done it I'll be doing a proper write-up, so any input would be appreciated
