I got my 7m down to bare block and now it's figuring out what to do next. I have already decided on what machine shop I am going to use, some of you might know Dave Henry and his 8 second mkiv supra from Fargo. He uses Quality Engine for his engines, so I am using the same place. No brainer.
Now, since my engine is all torn down, what should I bring to the machine shop? Block, timing cover, head, crank, pistons and rods and all bearings that I know for sure of, but is there anything else I should bring that I am forgetting?
When I drop the engine off, if I need pistons and a bore, should I have them buy them, or order from deiftmotion?Also same for bearings as well. Or should I order my own? (Cheaper?) Bear with me people this is my first time sending an engine to a machine shop and I want this right.
My goals are a stock non turbo rebuild.
Also, what should I make sure to tell the machinist? Any special things to be aware of? I would like to compile a list and have everything visually there to take note of. Easier that way.
I plan on having him machine everything and I will reassemble back in my garage. He will do the head.
Thanks in advance for your comments and concerns guys.
