7M with direct ignition-set-up with the eMange ultimate?
Breth
Breth
Dec 10, 2006
112
switzerland
www.erbacher.biz
Hi.
I have a 7M-GTE and im on wiring the eMange ultimate.
I wanna go direct ignition with jz-coils as example.
Did sombody did that before?
I was thinking i have to use the cam positioner sensor, and the crank positioner sensor to get input for the eManage. The Stockcoilpack i wanna keep, so that the stock ECU still works with no problems or just plug the stock coils out, but dont cut any stock wires. and then go with the "coonvert from group to direct ignition- wiring diagram" in the eMange-manual..
BTW: Is the crank-positionier senor in on the heasd in the cam sensor? Or do i hve to put a externe crank-sensor to my crank?
Breth
Another MkIII
697
Chicago
There is no Crank position sensor on the 7M, just the Cam sensor.
Also, I'm assuming you mean sequential injection and not direct injection? Because they are completely different. Direct injection uses a high pressure booster pump and special injectors to spray fuel directly into the combustion chamber, and that would be one hell of a custom mod, lol.
-AM3
