7m swap prob
maitai69691
280
hilo hawaii
i just swaped a use 7m in to my car got every thing hooked up but its not idleing very good. rpms are jumping from 800-1500 the only code is 32 maf but i just repacd it 2 days befor i spun a bearing and it was fine.I do have wire at the ecu plug broken ging to fix it first i think was the ect wire its blue w/ a red stripe.Im also thinkng it might be a vac leak. Any idas would be greate.im going to also cheack the timeing and mab try myold coil pack.
mista_sup
211
atlanta
might be running in idle mode. my maf went bad and when i put the new one on i had to reset the computer. try taking the terminals off of the bat. and let it sit for about 30 to 40 min. and see if that fixes the problem.
