7m-GTE upgrade stages
Status
Not open for further replies.
Ckanderson
2,644
The beach
Stage 1
K&N high performance air filter kit
3 inch down pipe
3 inch exhaust
*Optional* Test Pipe
*Recommended* 12 volt mod for fuel pump
Stage 2
Stage 1+
HKS BOV kit, or equivalent
3 inch turbo elbow
Boost controller
*Recommended* Shocks and springs
*Recommended* Brake upgrade (pad's, and or lines)
*Highly Recommended* 3 inch test pipe, or high flow cat
Stage 3
Stage 2+
Intercooler Kit
Hard Pipes
Metal head gasket (required at this stage, may be needed for earlier stages)
ARP head studs, or bolts (studs recommended)
Walbro 255 LPH fuel pump
*optional* Fuel pressure regulator
Stage 4 TUNING REQUIRED (Wideband, on a dyno)
Stage3+
Upgraded CT-26 (stock) turbo (57, 60, 60-1 trim)
Lexus AFM
RC 550 cc injectors
Fuel controller (e-manage, Super AFC, F-con)
Upgraded clutch (spec stage 2 or greater)
*Highly recommended* Bigger brakes
*Highly recommended* Coil Over's, and sway bar's
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Stage 0
Basic maintenance. Don't even start until you've checked all the vacuum lines, coolant hoses, and everything else that is going to head south on you the instant you try to add performance to a 15 year old car.
jester1341
topless and blown
Western Maryland
also i don't think i would list the FPR as optional the whole way thru, i've heard plenty of stories about walbro's 'blowing apart' the stock regulator :0
my 2 cents, good to have a guide line though :)
john
Status
