I finished my 7M dry sump this year, but car is down under construction
last 2 years, hope to run it by July-August.
I choose Peterson components - 3 stage pump, water/oil cooler, 3 galon tank. Used inline CM filter with disposable cartridges. You can buy washable 40mic filter from Peterson, but it is to coarse in my opinion. I bought it, but decided to use it in my th350 cooling circuit.
Regarding pan - you can find pictures of modified pan in Defiant 101mm stroker thread, there are many good ideas there.
I made it simple - cut off all pan internals and soldered mesh wire. I also use crank scraper. I bought 2 scavenging filters, but didn't find room for them. My freaking manifold has too long runners. Deeper pan is always better for power, even with dry sump.
If you want shallow pan to lower engine you have to be more creative.
I installed tank in front of passenger side rear shock tower, tank vented from the bottom into the frame rail. -16AN lines to and from the tank. Don't have pictures of the tank, I am away from home and will be there in June or July.
If you buy components from Peterson - use Crank drive hub, BBC, ATI, MSD (part # 06-4112) . It will fit over 7M ATI dumper.
Edited 09 May 2013: I learned that my ATI damper is 6.78" size, standard 7M damper is 5.5". So, driving mandrel BBC, ATI, MSD (part # 06-4112) will not fit standard 7M damper. Thanks to Josbeat who brought it to my attention
