7m destrok with a diffrent block
themadhatter
760
Vegas
i hope some one will corect me if i'm wrong but if i remeber right the 7m and 5m share the same block just the head ,rods,crank and pistions are different
yes, but the 5M crank doesn't work so well...
but yes, IIRC the 7M head bolts onto the earlier M blocks... (much like the 1J and 2J)
supramic
133
magnolia DE.
tissimo said:
yea if you change the block its not a 7m anymore
the crank is to short aron was building a 2.8 l 7m using the 5m crank. aron had to extend the 5m crank so that it would fit the 7m components
the two blocks that i was looking at is the 4m sohc which is a 2.6L and the 5m 2.8
does anyone know what the rods/piston from the 5m can take. from what i know the 5m has a moderatly low compression like a 8:8.1 or some thing to that effect so im thinking if the the rods can take 4oo then i would just need to go with piston
