6m or 7m crank
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
Depends on what year the car was made, some 89early dont have it late 89's do also 7m cranks are more counter balanced on #2/5 cylinder, hence the 6250redline. yeaa..
mickyg
7MGE MX-73
Sep 15, 2005
406
Melbourne AU
Yes. The stamp should be fairly easy to see and if you can't find anything obvious, try rotating the crank.
But it's probably easier just to see if the counterweights are there. They're fairly obvious. The 7m is fully counterweighted and the 6m is not.
Blackmk3
142
New Zealand
whats is the perks and downfalls of a 7m or a 6m crank? ive gotta 6m crank i was going to use on my rebuild and as far as i can learn 6ms just arnt as counterweighted? is that true...i mean ill get it all balanced up anyways
or is there other reasons that make the 6m crank perferable to the 7m crank or oppisatly
(sorry about the spelling)
Thanks
Nick
mickyg
7MGE MX-73
Sep 15, 2005
406
Melbourne AU
Allan_MA70 said:
You better not have a 7m crank in that motor of yours micky!
You had it long enough to check so it's your own fault! :)
Seriously though, I doubt it's got a 7m as the motor's likely a 87 or 88. Unless someone got a replacement crank for it along the way.
