550cc injectors
89gte
Regular
Apr 26, 2011
134
Tennessee
I used everything you mentioned plus new injector connectors with pigtails. Also before this modification, I installed a walboro fuel pump.
Jimbo
Creeper
Jul 15, 2009
263
San Jose
laxboy36;1792717 said:
I know this thread has been discussed enough times. But what are the items needed to put the 550cc injectors in.
550cc
Lexus AFM
You'll need a head and a fuel rail. Maybe some bolts.
radiod
1,342
Abbotsford, BC
Here's the shopping list if you want to do it all properly:
550cc injectors + clips (there are adapters, but most end up soldering and replacing)
Lexus AFM (blank casting works fine, the electronics from your existing will drop in)
Adjustable fuel pressure regulator
Fuel pump (Walbro 255lph or equiv)
J-tube drill out or bypass
Wideband O2
Apexi SAFC or equiv (to do some slight fuel adjustments usually Lexus AFM + 550cc combo runs fairly rich)
Fuel pump relay mod will help if you want to nail down tuning a bit more so you don't have a spike when it switches voltages.
This could all be found searching pretty easily, it's been covered time and time again :icon_razz
