5 angle valve job
I tried multiangle vale jobs on my 7M when I had it, failed pretty quickly due to the fuel I was using (LPG) but I imagine Unleaded isn't going to be far behind.
Went back to a 3 angle job with fairly wide seats and valve recession was a thing of the past.
(was a HUGE PITA as I was running one piece shimless buckets)
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,776
Long Island, Ny
Ever look into +2mm oversize valves? I know the standard oversize valves are only +1mm, but is there a reason that +2mm valves like in the 2jz cant be used? I would assume the valves are too close to each other or the side of the combustion chamber?
